During my last tb sync I KNOW the #1 screw got turned. Is there a proper way to reset it?
I am confused about why it should not be turned. The shops jail says to use it as a reference, but I think that is just process. How could it be that all the tbs will go out of sync except the first?
One of the times I synced my bike, I tried to bring the vacuum to factory spec's at idle. Adjusting everything BUT #1, kept the vacuum(as I re-call) below spec's. I messed with #1 (and of course didn't check the # of turns out, the book is messed up as it states something to the effect of
# of turns IN). BTW, I never got it to the overall
specified vacuum #.
Even with playing with the #1 screw, I couldn't get the vacuum where its specified. I ended up leaving#1 at
3/4 a turn out.
I've read (forgot where, #1 should be like 1-1.25 turns out). I thought about re-adjusting it out to 1 turn but
it runs SO GOOD at 3/4, I'm not messing with it. Again, IMHO, 3/4 to 1 turn out (for #1), you should be ok.
The re-sync at 4K, IMHO should be mandatory. In the several FZ6' I've synced,
ALL have had the
#4 cylinder pull harder than the rest at 4K. A little more fine adjusting brought them all in line at 4k (usually within 2mm's) and at idle.
Although I keep my idle normally at 1,000 RPM's by choice, I sync the idle at 1,300(the specified idle speed) and later turn it down.
Reading thru the Carbtune manual, I've found you may not be able to bring the vacuum up (or down) no matter what
but it really isn't important. Just getting all cylinders to pull as close as possible (10mm spec limit per the manual), unless you have out of adjustment valves, ignition issues, etc, is very easy to get to. All of the FZ6' I've done have been within 3mm's at idle and 4K RPM's..
Yamaha likes the bike on the warm side when doing this, however, I've found it takes a bit longer (depending on the bike). I have a heavy duty fan thats set on high, placed right in front of the header/radiator to try and keep temps within normal riding temps.
Re the sync componant itself, do a search, it was awhile ago, with pictures. As I re-call, it wasn't anything super major to do and the goo that was in there, was quite nasty...
