D
Deleted member 2349
OK so the plan is to use the Fused section of wires that come with the Battery Tender...This should cut down on fabrication time.
I want to add a 12v Power Socket And use the above wire to be my connection to the battery. Should just need to get (1) SEA Connector, (2) Female Blade connectors, a length of matching gauge power wire and some shrink tube and of course the Socket is in the Mail...
The fuse that's already there is only 7.5 Amps...
Can I use this or should I go to a 10 or 15 Amp fuse??
I plan on using this for Cell phone and GPS power.
