AlexL
Shiny Side Up
So I am adjusting my chain, for the first time, and I have it where I want it but the right side swingarm endcap has come loose and if I tighten the adjusting nut so that it's not loose the adjustment is off. I have included a video to show what I'm talking about. I can push on the rear tire to tension the endcap but then when I go to tighten the axle nut the endcap comes loose again.
Clarification in the video, I say the axle nut is tight, it is not, it has not been tightened yet. Also, what I ended up doing temporarily is tightening the left side adjuster, tightening the right side adjuster, tightening the axle nut, then loosening the right side adjuster and snugging it up to keep the endcap tight. The only problem with that is now the adjuster marks are off, which is bad.
So my question is, how do I keep tension on that endcap so it stays tight while I'm tightening the axle nut??
Thanks!
Thanks!
