Good evening and happy holidays to everyone. Happy New Year too!
I've already synchronized the throttle bodies with the Carbtune Pro 4 vacuum gauge, and I have to say it was a success! After spending about half an hour getting cylinders 2, 3, and 4 to the same level as cylinder 1 (giving them short bursts of acceleration until they stabilized), because it's incredibly difficult to adjust them. It's not a matter of millimeters or microns; you'd say you need to adjust by a smaller amount. If you go too far, the Carbtune's pivot rises too much, and conversely, it lowers too much.
Anyway, I went for a drive, because revving the engine from 6000 to 7500 rpm while stationary wasn't enough. It's true that when stationary it behaves pretty much the same as when moving, since the vibrations come from inside the engine (the cylinders).
So, once I went out for a ride and accelerated in second gear, going through 5500, 6000, 6500, 7500 rpm...
The change was quite astonishing, to the point that I'd say the bike feels different. It's as if it's been fine-tuned, and we're talking about an inline four-cylinder engine mounted to the frame by what are, shall we say, less-than-ideal rubber mounts.
I had to test it several times, as much as I could manage since the city's ring road is right next to my house, and I repeat, it was a pretty drastic change. I'd say the bad vibrations have disappeared by 95% to 97%. There are still vibrations, but they seem normal, nothing like they were before.
The mirrors now have a slight "numbness," so to speak, but it's nothing like before, when at the aforementioned RPMs the image would become completely blurry, making it impossible to see clearly.
I haven't touched the counterweights at all. I preferred to synchronize the throttle bodies first with the vacuum gauge, and since the result was positive and favorable, I'm not going to touch them.
So, nothing more to add. After a few years, it seems the problem is solved. If this helps anyone, well, here it is. I'll keep the vacuum gauge in case I need to repeat the operation in X kilometers. I hope I don't have to, and that the bike stays like this for as long as I own it.
After the holidays, I'll take it out on the road for a longer test and I'll share the experience here.
Best regards and happy holidays!
