nishy213
Hey guys, took it a shady shop to get the chain loosened up a bit because after doing the sprocket and the chain replacement it starting making a whizzing noise whenever i rolled on the throttle, so i thought loosening the chain would fix it. The chain is at at somewhat the proper slack now but i can still hear the buzzing noise coming from somewhere near the sprocket, doesn’t happen when it’s running up on a center stand. Anyways, i come home and see that the alignment is off and the ride side has no more screw room to push it back as in there’s nothing touching between the adjusting thingy that moves and the bolt that pushes it back. Any advice ?
