nhowar02
hello, first time poster here! I've had my 07 FZ6 for about 3 years now, put over 20k miles on her. first bike, its been a great bike!
so i have an issue with her. please bear with me, the most i do mechanically with my bike is oil and coolant changes.
i noticed i had some residual oil on the right side (while sitting on it) of the engine. i believe its the pickup rotor cover? so i washed the bike, went for a ride and isolated the leak. i eventually found the exact spot it was leaking from(as seen in the video) so i may just replace the gasket. here is the video of the leak, you can see it if you look closley.
https://youtu.be/2P3RI29ooSg
photos will be posted or attached
a couple things that were brought up to me. could it be a breather issue? too much oil?
has anyone removed this cover? can i do so without replacing the oil? and is replacing the gasket as simple as removing and replacing it? I'm going to go to a garage that has every tool that i would need(torque wrench, maybe someone who knows what they are doing
sorry again if i sound like a noob idiot and thanks again for any help!
