New brake caliper piston seals - which side is inwards/outwards?
You need to order them, Auto zone won't have them, if you look up on parts zilla, Yamaha is now selling the seals as a kit(you usually had to buy several kits). I would stick with OEM seals.
2006 Yamaha FZ-6 (FZS6V) Front Brake Caliper | Babbitts Online Part #7
Your S1 only two pistons on each side. Gently push the pads in slightly. Remove the caliper, then the pads. Then use the brake lever and brake fluid and hydralically push the pistons out with the brake lever.
Is it the fzs6v or fzs6vc?
I've got the s1 2006
If your in California(I know your in the USA) you have the "C" model.
Shouldn't make a difference for the brakes anyway. Ca has special emission stuff on that version bike.
Look up on any parts fisch and you'll have a choice of the reg FZ and then the FZ6 c.
The "C" is for the California model..
