andyfazer600
Hey folks,
Been kept away a while with work but back now and looking to get the bike good to go!
I fitted HEL brake hoses yesterday but have a few queries and thought you knowledgable folks could assist.
A picture paints a thousand words so I've attached some.
I'm fairly confident the rear is setup correctly, albeit the hose was a little longer than I'd like but it fitted.
I routed the main front hose from the master cylinder down to the left caliper (sitting on the bike) and used the double banjo connector to loop the second shorter hose over the mudguard to the right caliper. I think this the correct routing?
The original hose has a 3-way block mounted on the left fork, I was expecting to use this mounitng point to secure the new hose in place but nothing is provided, leaving the hose loose and bracket unused. Not sure if this is correct or I'm missing something from HEL?
Thanks in advance
Thanks in advance
