2007, if no fluid was interchanged inside the pump and the #11 O-Ring sealing the engine oil to the water pump is not sealing, it makes sense that the O-ring could allow engine oil past it.
FWIW: in the US this product is available and seems to work great. Head bearings, rear shock bearing, swing arm, Anything that doesn't spin at high speed, pivots, levers, etc... Bought in a cartridge tube plus it's water resistant too. Take a look. Should be able to find it at most parts stores.
Valvoline Crimson™ Grease
Multi-purpose lithium soap grease designed for commercial fleets.
Overview
Valvoline's Crimson grease (Red Lithium 12-Hydroxy) is a tacky, extreme pressure, lithium soap grease designed specifically for the commercial fleet environment }} And Many Yamaha's
Every Valvoline grease is formulated to stand up to a range of extreme operating environments and conditions. Across the board, Valvoline greases provide excellent pumpability, lubricate and protect while withstanding extreme temperatures and load stresses, and deliver outstanding resistance to water washout.
- Provides excellent performance over a variety of operating conditions
- Dyed red for easy identification
- Contains select extreme pressure additives to protect and lubricate during heavy shock loading periods
- Is fortified with oxidation and corrosion
Overview
