njoytheride
Hey guys,
I've been trying to resolve an issue but so far i've had no luck. According to a thread about replacing the FZ6 bars for FZ1 bars, there's one step that i have a hiccup on.
How to: FZ6 Bar Conversion w/ grip heaters - PNW Riders
When putting on the right side control pod (ignition), the little 'pin' that goes into the bars wouldn't fit, i would've had to drill into the bars. According to RedKat's instructions, it seemed to have worked without the pin so i removed it. When the control pod was installed, i discovered that it was moving around freely and using the throttle basically moved the whole installation around the bars - which is obviously very unsafe. I was recommended to use electrical tape on the bars to keep the 'pod' from moving around but i find it's too slippery and if i layer on then i cant properly attach the pod to the bars.
Does anyone have any suggestions in this case? Yes, i've looked into buying the little piece that holds the 'pin' in the control pod but i have to buy the whole thing which costs $100-ish + having to drill in the bars.
.. Heck, if anyone has a spare one lying around, all i need is the little piece itself, i'll even pay for shipping.
Thanks for reading,
~ Jonathan
Thanks for reading,
~ Jonathan
