No thanks to you 'orrible lot, I started with a mini hacksaw then with a cut started I used a Sawzall.
Cut was uneven but I sanded it the last 1-2mm and got it flat.
Victory! Well over one anyway. I'm doing the other one tomorrow.
Chris,
I think you mentioned the OEM spacers are 130mm stock. Does that ring a bell? (Found Answer in FSM) 131 mm. FWIW: a tubing cutter would likely be very kind to work with as it would cut the tubing straight and not leave a burrs like SawzzzzzzzZalllllll.
So, after riding the remainder of the summer, are you still happy with this and how it came out with the progressive rate springs?
Hyperpro wrote back with the unlisted spring rates: :thumbup:
Front: 8.5 – 15.00 N/mm
Rear: 147 – 227 N/mm
OEM INFO: Front suspension
Type Telescopic fork
Spring/shock absorber type: Coil spring/oil damper
Front fork travel: 130.0 mm (5.12 in)
Fork spring free length: 354.0 mm (13.94 in)
Min Length: 347 mm (13.56 in)
Collar length 131.5 mm (5.18 in)
Installed length 347.0 mm (13.66 in)
Spring rate K1: 7.40 N/mm (42.25 lb/in) (0.75 kgf/mm)
Spring rate K2: 11.80 N/mm (67.38 lb/in) (1.20 kgf/mm)
Spring stroke K1: 0.0–70.0 mm (0.00–2.76 in)
Spring stroke K2: 70.0–130.0 mm (2.76–5.12 in)
Recommended oil Suspension oil 01 or equivalent
Quantity: 467.0 cm³ (15.79 US oz) (16.47 Imp.oz)
Level: 134.0 mm (5.28 in)
Inner tube outer diameter: 43.0 mm (1.69 in)
Inner tube bending limit: 0.2 mm (0.01 in)
Optional spring available: No
All, please note, the first 2"++ inches of travel on the OEM spring are said to be at a rate of 0.75kgf/mm - hence the reason the nose drops so much when tapping the brake!
Rear suspension
Type: Swingarm (monocross)
Spring/shock absorber type: Coil spring/gas-oil damper
Rear shock absorber assembly travel: 50.0 mm (1.97 in)
Spring free length: 185.0 mm (7.28 in)
Installed length: 172.0 mm (6.77 in)
Spring rate: K1 127.40 N/mm (727.45 lb/in) (12.99 kgf/mm)
Spring stroke: K1 0.0–50.0 mm (0.00–1.97 in)
Optional spring available No
Enclosed gas/air pressure (STD) 1200 kPa (170.7 psi) (12.0 kgf/cm²)
Spring preload adjusting positions (Minimum) 1
Spring preload adjusting positions (Standard) 3
Spring preload adjusting positions (Maximum) 7
Swingarm radial free play 1.0 mm (0.039 in)
Swingarm axial free play 1.0 mm (0.039 in)
