AngelFZ
Did you flush all the old fluid out or just bleed them? If you haven flushed all the old out try that and you will be even more amazed!
I tried to do my best to bleed all the fluid out.
^ You mean let the MC go dry and pour in new fluid with the system empty? Does that keep water in the old stuff from seeping into the new stuff?
With that bleeder he has he should be able to keep pumping new fluid through untill all the old is out if I'm not mistaken
I am surprised no has mentioned speed bleeders. Take out the crappy ass stock bleed nipple and put in one of these. Open quarter turn and pump away!
You do not need to open and close the bleed nipple.
To those replacing fluid every year, why? If you need to do it every year, get the synthetic dot4. Fluid shouldn't need replacing every year.
is it definitely an 8mm spanner needed for the nipple? went to halfrauds hoping to pick up a set of spanners, but the decent ones were all £40-60
Fluid should be replaced every year if you really riding your bike. And I do use full synthetic dot4. If you just take it out every other weekend for 100 miles ride - every two seasons would be enough (I would still do it every year).
I ride my bikes a lot and I see how fluid is degraded after a season. It is cheap, fast (especially with speed bleeders or simple vacuum pump) so why not? Never skimp on tire and brakes maintenance.
I thought I'd bump this and get a few to do some maintenance as the season starts.
CHANGE YOUR FLUID FELLOW RIDERS!!!
Also take NOTE: DOT 4 BRAKE FLUID with its higher boiling temperature has a draw back. IT ATTRACTS MOISTURE AT A FASTER RATE THAN DOT 3 FLUID!!! The typical rate for absorption of DOT 3 Fluid is 1% moisture per year of service. It is rumored that some DOT 4 Fluids can double this rate especially in the high humidity areas.
NOTE: Adding 1% moisture can reduce the boiling point upwards of 40 to 50F.
In short, 5 years on DOT 4 FLUID has potential to cripple your brake system and cause a costly repair from corrosion damage to brake components! Not to mention potential HEALTH HAZARDS to the Rider!
Lastly; Throw AWAY any unused brake fluid and top off with or FILL UP WITH NEW FLUID from a NEW CONTAINER and do so on LOW HUMIDITY DAYS!!!
Rubber is permeable and absorbs moisture even though this system appears to be sealed well with its bladder style lids.
HOW TO BLEED: (from post above)
Straight from the manual and the way I have always done it successfully is this:
1. Bleed:
• Hydraulic brake system
a. Fill the brake fluid reservoir to the proper level with the recommended brake fluid.
b. Install the diaphragm (brake master cylinder reservoir or brake fluid reservoir).
c. Connect a clear plastic hose “1” tightly to the bleed screw “2”.
d. Place the other end of the hose into a container.
e. Slowly apply the brake lever several times.
f. Fully pull the brake lever or fully press down the brake pedal and hold it in position.
g. Loosen the bleed screw.
NOTE:
Loosening the bleed screw will release the pressure and cause the brake lever to contact the throttle grip or the brake pedal to fully extend.
h. Tighten the bleed screw and then release the brake lever or brake pedal.
i. Repeat steps (e) to (h) until all of the air bubbles have disappeared from the brake fluid in the plastic hose.
j. Tighten the bleed screw to specification.
k. Fill the brake fluid reservoir to the proper level with the recommended brake fluid.
Refer to "CHECKING THE BRAKE FLUID
LEVEL" on page 3-22.
IMO; pumping the lever(s) with the bleeder screw open is likely making allot of extra work trying to get the air out of the system and I would NOT advise performing such a practice.
Be safe.. .. ..
Good looking out! I need to go ahead and do mine again, been 2 years. :thumbup:
There was too much GOOD INFO in your thread to NOT do a little Recycling !!! :thumbup:
I read in other places about DOT 4 breaking down SOONER than DOT 3 and thought it worthy to mention it here. 2 YEARS MAX on DOT 4!
I got home a little while ago from taking my step son for a ride and decided to bleed the brakes. I pumped/added fluid until it was clear and bubble free. It took all of 20 min to do...eazy peezzy:thumbup:
The brakes feel so much better!
