I looked at the bike earlier today.
Noticed a couple of issues.
The tank appeared to be free of rust however I did note some scratches directly below the tank cap. The owner presumed they were from the gas pump nozzle during fill-ups. Does this present an problem?
It will need a new front tire in the near future and the owner acknowledged that and has adjusted the asking price.
In addition there are some spots of moderate rust on the chain.
One final note
It was cold morning (about 30 degrees) and the bike started right up, though there was a little smoking from the exhaust and the bike did stall when the owner threw some revs on the throttle. He started the bike again and bike did not have any more problems.
Seller claimed that brief smoke coming from exhaust was due to bike being run by for about 10 seconds and then immediately shut off by another interested buyer in similar cold conditions a day or so before my visit. He did not have an explanation for stalling, but said that he had never encountered it before.
If you can post a pic of the scratch on the tank but it shouldn't hurt anything but the looks...
Moderate rust on the chain likely means it likely hasn't been maintained, count on a new chain ( and possibly sprockets) worse case scenerio. Pull the dip stick on the right side of the engine, is the oil black? Shouldn't be if its been maintained...
As warm as it is down here, in the high 40's, on
start up, I'll get white, condensation smoke. Likely not a problem, once to FULLY WARMED UP, you can re-check it. BLUE SMOKE-
RUN AWAY....(its oil burning). Make sure when you go see it again, it HASN'T BEEN STARTED before you get there...
It does make me somewhat nervous when anyone
(especially a bike I'm looking at to buy) revving the crap out of it dead cold...
Not good... Does he ride this bike that hard all the time??
The engine is about bullet proof
but NO engine, dead cold, likes to revved to 6k, kits just not good for the engine, period...
As for stalling once, it
shouldn't have stalled, even cold. I would crank it up again from a dead cold start, (NO THROTTLE), it rev a little high cold and settle down to about 12-1300 RPM's
Let it warm up some and go for a ride... Once fully warmed up (OIL TOO) you can go for a ride and wind it up checking for unusual noises, hard shifting, jumping out of gear, etc...
If you have a trusted mechainic or very mechanically inclined friend familiar with bikes would be worth the investment to look at it with you...
**If you
can post several pictures, from all angles, it'll tell a bunch about the bike, possible tip overs/crashes, potential front fairing damage, etc.
