Will this battery fit?
outasight20
Long Island
So I accidentally left my ignition on all night and my battery is completely dead now. It is dated as being made in March of 2008 according to Yuasa. Probably installed in 2009 so that makes it about three years old. Sounds right.
I want to buy a Yuasa and sears only has one designated with a "12" in it. It is the one linked to below:
YUASA battery for Yuasa Maintenance-Free Battery YTX12-BS YAUM3RH2S - Automotive - Batteries - PowerSport Batteries
Will this fit?
If not, can anyone point me in the right direction as to which (quality) battery will fit and can be bought at Sears?
Thanks guys.
The recommended battery from Yuasa is the YT12B-BS.
The size is: 6 x 2.75 x 5125.
The battery you saw, the YTX12-BS is a different size: 6 x 3.44 x 5.125.
I'll probably call around to local bike shops tomorrow and see if anyone has the right one. Any cheaper options for batteries? Or do you get what you pay for?
The YT12B-BS looks to cost around $100.
I've found you get what you pay for. Here's your original battery a little cheaper ($80.00):
Maintenance Free Battery - YT12B-BS $80.16
________________________________________________________________________________________________
FYI, from the Battery Tender site:
Background: The motorcycle dealers receive batteries from the manufacturer in a dry state. The plates are dried out, and there is no acid in the cell compartments. (Do not confuse this with a dry-cell battery.) The dealer must fill the individual battery cells with acid and then put them on a shop charger to pre-charge prior to selling them to a customer. As the batteries arrive from the manufacturer, the plates are approximately 80% "formed". The initial pre-charge, post-formation charge, or more correctly, formation-finishing charge, must be conducted at a specific power level and for a specific time period. Each manufacturer has its own recommendations, for example one manufacturer recommends that the charger deliver a constant current equal to 10% to 15% of the battery amp-hour capacity and that the charge current be applied to the battery for a period of 5 to 10 hours.
Answer 1) Certainly if the dealer has properly pre-charged the battery after filling it with acid, then the answer is ABSOLUTELY YES.
Answer 2) If the dealer has not properly pre-charged the
newly filled battery prior to the sale, then the answer is YES, WITH SOME QUALIFICATIONS:
Qualification A) The Battery Tender® Plus should be left on the new battery for a minimum of 24 hours on float, in addition to whatever amount of time it takes for the charger to get to the float stage. It is not clear how to correlate the 80% formed plates with a given state of charge once the cells are filled with acid. To be safe, assume that the batteries require a full 100% charge after the cells are filled.
I ended up picking up a Yuasa from my local dealer. I filled the acid and let it sit for about an hour then stuck it on my charger. Charged for about 5 hours at 1 amp and now I'm starting another two hour cycle at 1.5 amps. The voltage at the moment is at 13.26 volts and climbing slowly but surely.
Is this an acceptable voltage for a new battery post-charging? I need to ride the bike tomorrow so I'm deciding whether to pull the battery off the charger tonight (after the 1.5 amp cycle) and install it or let it charge at .5 amps overnight.
What do you guys think?
Most chargers are automatic and will go green or indicate a fully charged battery. It should really sit charging until you get the "green light".
Most chargers start at a higher unput, say 1.25 and add voltage at a lower rate as the battery nears full charge.
IMHO, I wouldn't bump the charge higher at the end as you get closer to full charge.
If its not an automatic charger, your probably ok, see the BOLD part I posted below. 13.2 volts is apparently the magic number..
_________________________________________________________________________________________________
FROM THE BATTERY TENDER FAQ SITE:
For example, a 16 Ah battery will take about 13 hours to get to the absorption voltage (constant 14.4 Volts). It may take another 6 to 8 hours to reach the float voltage (constant 13.2 Volts). This may sound awkward; because what happens is that the battery charge current drops while the absorption voltage is held constant. When the battery current drops to 0.1 amp, or if 6 to hours have elapsed at the absorption voltage, the charger automatically switches its output from 14.4 V to 13.2 V. So it may take the better part of 20 hours to reach the float stage. Add another 24 hours to that and you are at 44 hours. Throw in another 4 hours for good measure and you get a nice round, even 48 hours, or 2 days.
Qualification B) Although there are probably several charging methods that will be equally
