yamihoe
Professional test dummy
So with 25,948 miles on the odo I had enough time, and beer, to do the valves.
trip 1-167.8 (miles on that tank)
trip 2- 1910.2 (miles on oil change)
the intake valves were to be between .005-.008"
the exhaust valves were to be between .009-.011"
Intake- cylinder 1-(.006,.007) 2-(.006,.006) 3-(.006,.007) 4-(.007,.006)
Exhaust- cylinder 1-(.011,.011) 2-(.010,.011) 3-(.011,.011) 4-(.011,.010)
The whole thing is a bit of a pita but not unmanageable or unachievable in a few hours. I did not need to replace any gaskets but I did take a dab of silicone and run it around everything for good measure.
I took a few pointers from-http://www.fz6r-forum.com/forum/f91/fz6r-valve-adjustment-24098/ .
I would highly discourage anyone from doing this themselves if they have any doubt in their mechanical abilities!!!!
if you get any kind of trash (dirt, debris, etc.) into your engine it is VERY BAD. I took it for a little ride to make sure there werent any leaks and to run everything thru the oil filter once more before changing the oil.
I took the time to put some fancy new lights on there as well
Unfortunately on my way to get oil and a filter from work my car decided to try and kill itself....so i grabbed oil, a filter, AND a whole new intake manifold....so that took up the rest of the night.
NOW TO RIDE MORE!!!!!!!:rockon:
