davidmacknh
Is it alright to keep my high beam on at night for prolonged period time on 2006 fz6? Will I burn out the bulb?
bd43 mod for the win! (wire that clips into existing harness and utilises the lowbeam of the H4.)
Do a search and if he's still got some, it's the best mod you can do - and it plugs into the stock setup with no cutting of wires etc.
Cheers,
Rick
Can u put that simpler for me?
A gentleman by the name of Daryl (username bd43) makes a wire you can buy that plugs into the factory harness, in the factory plugs. It replaces the wire that Yamaha removed to meet Euro-spec.
The wire enables low beam on the H4 bulb, so on low beam, you have BOTH lights working and greatly increases visibility.
I purchased the wire off him, plugged it into the plugs (instructions also provided) and it works perfectly.
You need to lift your tank to fit this, as that's where the plug you need to connect to is, but otherwise that's all you need to do.
No cutting any wires, no changing plugs etc.
Cost me $38inc airmail shipping to South Australia.
Do a search, as I can't find the link on my phone.
Cheers,
Rick
P.S. I still have his return correspondence so I have messaged him this thread and if/when he sees it, no doubt he'll be in touch. Cheers.
+1 on the above, a lot cheaper in the states too.. In heavy traffic, I run the HB on for extra visability as well... PIAA also makes "powersport bulbs" that draw the same amount of watts as the stockers but put out over 100 watts of light, very recommended..
Actually the wattage rating is for it's power draw, light output is measured in lumens, the PIAA lights will draw more power and produce more heat. If higher light output is your goal, I would shoot for an HID conversion, the added heat from the PIAAs probably won't be an issue but the increased power draw may be an issue with the low current put out by the stator on these bikes. x2 on running the high beams during the day
**edit** looks like they are using marketing english, they seem to have the same wattage rating as stock, but they are claiming it to be brighter by an undetermined amount and they don't list the lumens, fairly typical marketing stuff
So when they advertise,:
Description
H4 60/55W=110/100W Xtreme White Anti-Vibration XTRA, Single
Its not putting out more light but just drawing more power?
BTW, I've been running these bulbs for about a year and a half, idle at 1,000 (discharging at idle) RPM's and have never had an issue with the battery..
Actually wattage is power and lumens or candlepower are light measurement. What I think happens is PIA is saying that if you had a bulb that used 100watts of power and it performed with the same characteristic efficiency as the 65 watt it would put out the equivalent amount of light as a 100 watt lamp but use 65 watts. Marketing has to somehow falsify ideas because they look down at consumers and know that dumbing down the information sells more product (i don't know if that's true). Don't worry about what the information means to the consumer just tell them it's bigger, better, newer and most of all if you have one your neighbor and friends will envy you!
The claim that the PIA states may in fact and is probably true as far as lamp efficiency but wattage equals wattage and does not have to mean more lumens. I think Joe and Joann Consumer are smart enough to understand lumen or candlepower ratings in lieu of wattage.
They also do this with vacuum cleaners. You'll see amperage ratings to signify one sucks better than another. And yes amps times voltage is wattage!![]()
Question: These bulbs are brighter than the stockers (visably) as was the single (similar bulb, single bulb in my old KLR250 where it was much more noticable).
So they are not brighter than the stockers?
What does the 60/55W=110/100W mean?
I keep my high beam on all the time in the daytime for visability & whenever there's no oncoming traffic after dark & 5k miles later it's still burning bright! I actually can't wait for it to burn out so I can upgrade to Silverstars! :rockon:
