wont rev past 8k
That's weird. It should go all the way to redline in every gear except maybe 6th depending on your altitude, weight, ect.
Does the power hard cut off at 8k? Does it bog down? What happens exactly?
Didn't you just get your bike? Has it done this since you've had it, or just started? They make restrictor kits for the bikes, I'm not 100% sure how they work, or what they do but I do believe that they limit the RPM's. Maybe your bike has a restrictor kit on it
In addition could ther be a limiter on the throttle linkage or is there a limit to wide open throttle? Check you linkage..:D
Edit: Haha..Beat me to it!
i actually just picked it up, it starts to bog down around 7K and at 8K it just wont rev any more, if i shift, it runs fine, but it is in every gear
Disconnect the battery negative lead for a few minutes. Reconnect and take it for a ride.
I vaguely remember reading something about bikes having a RPM limiter if the rider is underage. I think it was one of the Nordic countries, maybe that's it?
Sorry bud but it looks like that plate that restricts rotation is a stock piece!
Took this just for you a min ago on my 06'
And this is throttle rotation
Closed
Wide open
Sorry to hear of bad news this early in your MC ownership! Be very specific when describing issues and the collective knowledge here will pull together the best a bunch "bikers" can.
Also, research getting your readout into diagnostic mode and you can look at you Throttle Position Sensor to see if it's putting forth the numbers you need. This would tell you the TPS is good/bad and whether you've got full range mechanically in you throttle linkage.
Was it this guy?!
it may possibly might be restricted, mines restricted under uk law as im not 21 my throttle action looks very similar to that above, and its all throttle restricted and that plate looks very familiar
He has a US bike, New Braunfles is in Texas. Okay Texas can be like another country but not in this case.
I wonder if the bike sat for a while? Try adding Seafoam to your fuel for a tank and see what it does.
Also, is the air filter clean?
Totally agree it could be this. ^^^^ You could have stale gas... I've seen SeaFoam do great stuff for many different symptoms..:D
