OK - so lets get a base line; 3 bikes seem sluggish off the line.
Lets weed out the obvious; bike is above 150F (66C), you take off in 1st gear at 1500 to 1700 and accel to 4000RPM.
If you do so quickly it stumbles, misses, won't accelerate, backfires, bawgs, baulks, stalls???? Would those decribe how these bikes run?
I've mentioned this before, but not all FUEL is created equally. Switch brands and if you're using the lowest octane mix, bump up a grade and tell us what it does. Fuel that is slow to burn (for what ever reason) can easily cause all of the above issues off idle at low RPM under load.
The fuel will seem fine at upper RPMs but it fails to deliver expected performance at low RPM. It happens.
Look at this eye strain chart below I made using live data and crappy gas from the OBDII port on my auto. This engine can easily pull 42degrees of ignition advance. Notice the red line and the blue line? The blue line is the engines calculated load based upon TPS, RPM, air speed through the MAFS etc... The Red is the IGN advance which is roughly 22 deg until it shifts into second whereby it goes into Ignition Retard pulling the advance negative killing the engines performance. This is from crap gas. On a different day from the same station, from the "same" octane pump the car runs fine. Yes, this is at 6000RPM but the same effects were happening at low RPM while pulling hills. It would hesitate, and feel sluggish so I'd open the throttle more and nothing changed. All I had to do was switch gas and it fixed itself.
Give it some thought before putting a bunch of effort into the above problems. Also - which of you run Highest octane pump gas?
