erar
Thank you Sanger A2
erar
erar
Glad it was useful to you. It's a bit uncomfy cut this low for more than 30 mins, the 2cm of gel I added later helped. But I'm planning on removing all the foam and just having gel later.Thank you Sanger A2
erar
Yeah a bit more. But the stock foam was never comfy. I added 2cm of gel which made it brilliant. I'm going to replace all the foam with gel on the main rider's section of the seat to make it even more comfy.Good job on the seat. Quick question-by removing the foam, did you increase the vibes going through the seat? Thanks
No probs. Just take it slow. And make sure you post pics when you're done!Thanks Sanger_A2 for this thread! I now am brave enough to tackle this mod!
I bought a gel numnah designed for horses to go under the saddle. Equigel is good as they are massive and can be doubled over and still cover the whole saddle. I've bought a second one that I will add in when I have free time and take out all the foam on the rider's seat (or most of it).Sanger, where'd you buy the gel insert?
it turned out pretty good and it didn't cost me anything since I had the staples. I just have to work out a few wrinkles in the cover.
I decided to shave the seat from the bottom today. I didn't want to take the time to cut and sand the top of the foam so it wouldn't be lumpy. And to be honest, I'm not in love with it. It hasn't really lowered the seat where I can flat foot the bike. Only cost me $23 for a staple gun and staples though.
Yeah, changing the shape is where it matters. Mine is completely different from stock. Much rounder, I sit further back, much less wide and much lower. Just taking a bit of height off it won't change the problem with the overall design.I think you should try it from the top that way you can change the shape. Narrow out the area that is in between your legs when you are at a stop and dip down the area where your arse normally sits. I had good luck with it, about 3/4 to an 1 inch. Its not that big a deal to smooth it back out with a sanding block.
Good luck.
No idea mate. It hasn't rusted yet after being used in all weathers. Not much moisture gets them anyway!And Sanger, thanks for the post! :thumbup:
One question tho - did you use stainless steel staples so they don't rust?
