Per the manual, the bike should be warmed up and at idle (12-1300 RPM's). #1 screw is NOT ADJUSTED, adjust the rest to bring them within spec (10mm). Depending on the bike, you can usally get them MUCH CLOSER (mines at 2-3 mm's difference).
Although the manual doesn't call for it, I re-check AND adjust at 4,000 RPM's as thats where a good amount if buzz comes in at. I let it idle down and re-adjust if necessary. You'd be really surprised
how far out it can be at 4K and look level at idle. Beyond 4K, the throttle blades are open a bit so your really not dealing with that circuit anymore. Its pretty easy to get the engine within 3mm's at both idel and 4k RPM's. I doubt most dealerships would do that as time is money, heck its within 10mm at idle, button her up and collect $!
As for the butterfly screw on the FZ, there's only ONE, inbetween TWO sets of TB's that should NOT be touched.
Just as a side note, on my old FJR, it had FOUR separate TB's and of course butterfly adjustment screws inbetween them (again don't adjust those). The adjustment springs actually have a spot of white paint on them. Adjustment to the TB's are the same as the FZ but at each TB vs the
one block the FZ has.
I had paid a Yamaha dealership, years ago to sync the bike (over $125). I later found one of the painted, do NOT ADJUST screws, with painted spring
adjusted approx 1/8 of a turn... GD it! Pay an Yamaha mechanic to do a proper sync and that's what you get.
Got my
Carb mate for the FZ (to eliminate some buzz). Reset the FJR spring BACK TO stock (the paint mark lined back up) and re-synced the engine properly. A review:
http://www.ridermagazine.com/gear/morgans-carbtune-pro-mechanical-manometer-review.htm/
That is exactly why I won't go to the dealership unless absolutly necessary. I actually wouldn't even go there, there's a local guy I trust vs being a "Yamaha trained" newbie, lazy mechanic screwing my bike up. There are plenty of good mechanic's out there, just got to find them..
BTW, couldn't vote as the option wasn't there, my Carbtune was $82 delivered from England 3-17-09
