Cross Reference of Specific Oil Filters:
deeptekkie
TN
I have seen on three different sites where some folks use a SuperTech 7317 oil filter on their Fazers. (So far I have tried only Yamaha and Fram filters)
What is interesting is that the SuperTech cross reference number over to a Fram is a PH7317, NOT the Fram recommended PH6017A. Any idea what gives? Thanks.
Never mind - found it. A guy on another board said that most Jap bikes all use the same threads and that most current bike filters are all interchangeable.
The price is really attractive: $3.95 verses $14.95. Reviews say it's a top-end filter. Too, it's longer than a stock Yamaha filter which to me seems better, whether it contains more filtering media or there is more surface area exposed for additional oil cooling)
I use the SuperTech. Though the last time I went to buy one they were out so I got a Bosch. About $6.
Wix brand:
Part Number: 51358
UPC Number: 765809513587
Principal Application: Honda Motorcycles + Industrial Engines, I-R, Honda (87-10), Komatsu, Kubota, Kia (95-05), Mercury, Arctic Cat, Nissan (06-11), Polaris, Subaru (05-06), Yamaha, Other
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/52
Burst Pressure-PSI: 265
Max Flow Rate: 8-10 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
I usually use Purolators Pure One filter. Either PL14610 or PL14612. I usually hunt around for sales.
Although I have used the following:
Napa Gold (WIX) 1356
Amsoil EAOM103
Bosch 3400 (IIRC)
Super Tech 7317
Fram Tough Guard TG7317
I am not a fan of the Fram Orange can though. I had a few issues with them, but many use them without issue.
There was a very good thread in 2008 about filters.
http://www.600riders.com/forum/garage-mechanical-help/204-oil-filters-will-fit.html
Good luck
