alittletoored
2006 FZ6 Will not start. I have looked at everything, but nothing that I can tell is wrong.
Battery Good Shows 12v
Kick Stand switch Good Had resistance through
Kill switch Good Shows twelve volt power when in the on position
Starter Switch Good Shows around 9v going to it and zero when not engaged
Rear fuses are good.
Front 30A fuses are good.
Power is going to the starter Via the Power cord through relay, assuming relay to be good.
I beleive that the Neutral Safety switch is working. It has some four volts flowing to it and when disconnected the check engine light comes one. However, the neutral light on the gauge cluster is not on. Im not sure if it even works though.
I am currently looking at the wiring diagram, but it is rather hard to make heads or tails of. :banghead:
Any help would be much appriciated.
