chrisdot1
it does it constantly, up down up down ......new batt was fitted what do i need to do to resolve this please?.
Did you dislodge any wires when you lifted the tank to fit the battery ?
I would look there first.
:rof: I can only type one handed at the moment mate.Beat ya by 15 seconds...........![]()
ok so i lifted tank and removed headlight and split speedo all cables seem to be fine so im taking it to hursts to get ecu reset.
as of this mornin....will start no problem in neutral as soon as u engage gear engine stops.....
stand is up
Soiunds like your clutch safety switch (by the clutch lever) is dirty. Squirt some WD40 in the vent hole, also where the switch goes in and out and work it a couple of times.
Its also possible the kickstand switch is gooed up. Even thou its up, if its dirty, it'll mtell the ECU that its still down. Its easy to take apart and clean (one spring thats tame-won't shoot 12' on ya)..
sorted.....thank you so much....just did both stand and clutch switches but me thinks it was stand one as it was minging to the max.
Whats minging to the max?
