Eviloliv3
I'm here for the women
So I didnt see any thread with a "how-to" on frame sliders. So here goes with all the pics i took. i know its easy but i had some free time...
So first you will need the get some frame sliders. The ones i purchased were from Uncaged and arrived in a few days. They come with longer bolts, the mounting hardware and the tips which is the part that comes in contact (hopefully not) with the ground.
First you will need the correct Allen wrench size. I do not know the exact size of the allen due to the tool being old and without writing on it. I just dug through the drawers in my fathers chest til i found a fitting on. If you need, take the bolt in the kit to a local autoparts store. Most stores will let you borrow tools for a little while. the bolt was slightly tighter than hand tight, but not too tight.
take the new bolt and use the washer off of the old bolt for extra support.
insert into slider hardware and thread in by hand until flush, then tighten up to manufacturers specs.
