I'm a bit confused now.
So, the bike I just bought has 1,200 miles on it and I have no idea what type of oil they have used. I suspect that it has been fully dealer serviced so far.
Should I wait another 600 miles or so and change with 'normal' oil or should I go semi-synthetic? I'm going to change the air filter as well - probably going with K&N for that.
Run what ever oil you like. Just stay away form "automotive" grade oils, as the friction modifiers can be bad for the clutch plates. These oils will say "energy conserving" on the star burst API symbol, and are usually thinner weights like 5w-20, 5w-30, 10w-30. I am a firm believer in synthetics, and have used them for many years with no ill effects.
Any HDEO (heavy duty engine oil) will work fine, such as; Rotella T 15w-40, Rotella T Synthetic 5w-40 and numerous other "diesel" oils.
You could change it now if it makes you nervous, but the dealer oil is not that bad, your bike is most likely just fine, again, run what you wish.
I personally am going to run Repsol, for awhile. I was up at the International Motorcycle Show in Minneapolis last. weekend, and a vendor was selling Repsol 10w-40 full synthetic for an unbeatable price, so I picked up nine liters.
The myth that synthetic oil will not break in an engine was back when synthetics were first coming out. Back then synthetics caused all sorts of problems, including swelling oil seals, so when you changed back to conventional oil, everything leaked. This wifes tale of engines not seating in were in the day of poured bearings, here the oil was too slippery and never caused enough metal on metal contact to properly "run in" the bearings. Modern engine tolerances (and machining) are so good, that break in pretty much means seating the piston rings, which oil has very little to do with. I found the best way to seat the rings is to put a varying load on the engine. Stay within the allowed rev range, but do not be afraid to accelerate, and decelerate the engine. Of course, always allow a proper warm up first, and never just let a new engine idle or not fully reach operating temperature. Hope this helps.
