fazer.rider
Super Member
so my shifts got a little clunky at low speeds in low gears and i was wondering what's wrong. i realized my chain was kinda dry so i soaked it with chain lube and the clunky shifts were gone. correlation anyone?
QUIZ: On your o-ring chain, WHERE are you spraying the lube and why?
Is the chain warm or cold and why does it make a difference?
To the best of my common sense.....
I try to get at the O-rings and rollers. The lube should be keeping the o-rings from dying out and causing failure.
Always warm, the heat expands the rings and allows the lube to penetrate.
Pay attention folks! abacall's common sense is better than some rider's "facts"![]()
:thumbup:
Yey for me! Now where's my rep?![]()
abacall said:I do lube every time I wash or ride in the rain or on dirt road, or every 500 miles or so.
The chain is a very serious piece of equipment on a motorcycle, not lubing it is way more dangerous than not changing your oil, and we all do that when we're supposed to.
I take a minimalist approach with chain care. 90 wt gear oil, on a rag wiping down the chain 3-4 laps around the entire thing. Maybe once a month. Rain or shine. The OEM chain is at 23K miles, and has finally developed a stiff link. Pretty reasonable life, in my books....
Snipped but not forgotten..
The O rings are designed to seal in the lubrication installed at the time of manufacture.... anything that disturbs the seal between the side plates, roller, and O rings is going to allow dirt to penetrate the wiping area, and cause wear to the O ring.
Once the O ring is compromised, the lubrication put in at the factory is going to migrate out, at which point the wear on the chain will accelerate on that link/pin bigtime.
RJ2112 said:I'm not fond of sticky spray on stuff... haven't found a chain wax that makes a significant difference to chain life, but every one I tried added a lot of time to cleaning up afterwards.
RJ2112 said:I object to the idea that a bristle brush of any sort is going to improve the O rings' life. You poke a needle at a gasket.... you're not prolonging the gasket's life......... even if you don't nick the ring, unseating it from the wiping surface potentially allows the grit you have already disturbed to enter that area. 'Just a pinch of sand, between your cheek and gums'. I honestly don't see how that is a good idea.
RJ2112 said:Some folks take off their chain, and submerge it in kerosene.... seems to me, that will dilute the lube inside the rollers, if it penetrates.... then it should migrate out that much faster.....
RJ2112 said:Every spray on chain preservative I know of, HAS to use a thinning agent, to allow it to be sprayed out of an aerosol can.... the stuff is runny, until that thinning agent evaporates. What happens, if that thinning agent gets inside the O ring? .... seems to me, that will dilute the lube inside the rollers, if it penetrates.... then it should migrate out that much faster.....
RJ2112 said:I recognize the 90 wt I apply does not do any more than other products... but I think that limiting the amount of damage I do to the O rings lengthens their life. Preserving the OEM lube inside the pins of the chain to the greatest degree I can seems the best course for ensuring a long chain life. In my view, the gear oil does as well as anything I've seen on limiting corrosion on the exterior of the chain, and is almost certainly not doing any damage to the O rings.
If the oil I add gets flung off, there's a better than even chance it will take the grit and grime with it. What remains, I do not want to drive into the O rings.
.02
Cali rider.....
I assume you are using 1.5% chain stretch as your decision point? That's any point on the chain, right? Center of pin to center of pin, measured in millimeters? If I may ask, how often do you check this, and at how many points in a given sampling? (I'd think there would be no need, with less than 15K miles on the chain.... I have yet to see stretch at less than that, with a properly tensioned chain.)
First off, chains don't "stretch", they wear.
I inspect chain/sprocket wear about every 5,000 miles. Check 4-5 random nine-link samples, under tension, with a 0-6" caliper, across the pins as shown below, all dimensions in inches. New length is 5.825", when the measured length exceeds 5.912" replacement is needed.
..........Also it's better to let the chain to be a bit loose rather than too tight.......
