Horn saved me again...
Is there any respectable horn out there that will mount (easily?) into the same spot as the stock horn and can be directly wired (i.e. not require a relay)? I'm thinking it might be better to get the occasional "stink eye" for accidental honking rather than a left front fender ...
+1 on that, any recommendations?
For what it's worth, I have my Stebel mounted where the original stock horn is located. One bolt and it's good. I used part of the exhisting two wires for the horn to connect to the stebel and used a heavier gauge wire to go from the relay to the battery. I spent the extra 12 bucks and bought the wiring kit, which included the relay.
The Fiamm freeway blaster is a significant upgrade over the stock horn if you don't want to install the Stebel. Here's how I did it:
http://www.600riders.com/forum/fz6-mods/196-fiamm-horn-mod-2.html#post203488
