This will be MSF Range Exercise # 14 - Stopping Quickly In a Curve.
As mentioned by another member, in order to stop quickly or if you have to engage emergency braking during a curve, straighting out the bike will provide you with the most effective way to stop quickly because it will provide you with the most traction.
I don't think anyone can/will debate that.
I was under the impression we were talking about applying the brake(s) while cornering which is very different than attempting to bring the bike to a complete
stop. Thre is a big difference between Cornering and Stopping.
I think if you watch Wavex's video of him crashing his FZ6 due to cornering too fast, you can see that he immediatlely had straightned his bike out during the curve so that he could give himself the maximum amount of braking power before he went off the road. So what if most of it was on the shoulder with gravel, main point is that he got away from the lean. This essentially saved himself from serious injuries because he managed to slow down enough where he was able to ride out the crash, well almost.
Was he really cornering "too fast" or did he crash because he
perceived that he was cornering too fast and failed to continue TURNING.
He "got away from the lean" That's not a good thing when you're trying to make a corner
He saved himself? Sounds like he drove off the road to me and is lucky to be alive.
IMO (and I was not there), the only thing he could have done worse is to not have slowed down at all AFTER making the decision to cease turing while in a turn. I'm guessing he would agree.
Are you really suggesting when you come in too hot you should stand the bike up and brake in a straight line? Perhaps in limited situations. Just based on my vague memory of the video in question, he should have looked and leaned. IIRC he mentioned the fact that he was upset with himself for not simply making the turn as it was doable at his speed. I could be remembering wrong.
Although the real advice is to ride at a pace you can handle, I'd hardly suggest that braking in a straight line toward a cliff is a good way to go when you get spooked.
What am I missing here?
PS - for the record, I crashed as a n00b by
GRABBING the front brake in a decreasing radius turn (about 3/4 through) a fraction of a second after fixating on the edge of the road. Total rider error...could have rolled on through with significantly more speed if I had known what I was doing. US129...
