That is true, it´s the same bike and it´s very easy to change the 78 hk version into the 98 hk version. I have the 78 hk version and have changed it into 98 hk, only took about a minute. The limiter is on the throttle as Toympas sad.
Hope i can explain this so you understand since my first language isn´t english, but i will give it a try.
If you look down onto the engine under the gastank on the left side and move the throttle back and forward you see a wheel that turns this wheel holds the throttle cabel. If you look at this wheel you will see two stops, one that will only make you turn the throttle about a quarter. If you look further back on this wheel you see another stop that will make you turn the throttle even more. This is the original stop that is used on the S2 version. If you just bend away the first stop you will be able to turn the throttle all the way and you will be able to use all the 98 hks of the enginge, it´s as easy as that. So if you don´t want ABS brakes on your bike and can live with having the old instumentation and not the new one from the FZ1 then there is no need to buy the S2 version of this bike since it´s so easy to change the 78 hk version.
We have a motorcycle magazine here in Sweden that also has looked into this bike in their last number and they verified that Yamaha has only made this modification to the bike to get it to 78 hk. This was the fastest and cheapest way for them to do it.
Hope everybody understand what i tried to explain
