Will not go into TPS dIAg mode
eagle1909
The EAgle
Binghamton, New york
Due to an idle problem I wanted to check my TPS. I read the thread on how to do this. Last night I went out to my bike. Held the buttons in and turned the key on. After a few seconds it went to dIAg. I then attempted to press the "select" button as the thread says. But the screen did not change. I attempted to do this several times. The bike running the bike off. Tried numerous times taking in and out of dIAg mode. Just couldn't get it to do anything else.
HELP!!
Thanks:thumbup:
eagle1909
The EAgle
Thanks for the link, I found this post. I will try it out tonight. :thumbup:
"After you get dIAG up on the screen you have to press SELECT and RESET again for 2 seconds to go into the Diagnostics mode. The default is the TPS check.
Setting the diagnostic mode
1. Turn the main switch to OFF and set the engine
stop switch to OFF.
2. Disconnect the wire harness coupler from
the fuel pump.
3. Simultaneously press and hold the SELECT
and RESET buttons, turn the main
switch to ON, and continue to press the buttons
for 8 seconds or more.
All displays on the meter disappear except the
clock and tripmeter displays.
dIAG appears on the LCD meter.
4. Press the SELECT button to select the CO
adjustment mode Co or the diagnostic
mode dIAG.
5. After selecting dIAG, simultaneously press
the SELECT and RESET buttons for 2 seconds
or more to execute the selection.
6. Select the diagnostic code number that applies
to the item that was verified with the
fault code number by pressing the SELECT
and RESET buttons. "
