Pseudo-Fed
Thanks for the help.
Hi,
My 05 fz6 recently had low idle, around 1000 rpm when warm, it sounds sputter at idle and jerking at < 3000 rpm. So I adjusted the screw and with the screw all the way in, the idle raised up to 1200 rpm, the bike is a little smoother and the idle sputter sound is reduced a lot, but still I can't get standard 1300 rpm idle. What else can I check?
I am planning a TB sync, but will it effect idle rpm? basically what can cause my idle too low and can't be raised up by that screw?
Thank you.
