- Joined
- Jul 26, 2007
- Messages
- 873
- Reaction score
- 13
- Points
- 0
- Location
- Colorado Springs, CO
How long do you let your FZ warm up when you first start it before you ride off?
Not long - especially when I'm worried about annoying the neighbors and waking the baby in the AM. Just long enough to let the idle steady a bit and then I take it easy (under 6k rpm) until the light stops blinking.
Edit: do the newer bikes with analog tach have a blinking light until they reach temp (like the digital tach bikes) or is it just the ability to read the coolant temp on the display?
I do the same thing. Even though it says its ok to ride when its "Lo" I never do. I'm never in such a rush i cant wait about a minute or so for it to warm up a bit. I usually start it, then put on my helmet, sunglasses, gloves and then mount the bike. By then it usually is warmed up.For my '07, when I first get a numeric value of coolant temperature to display.
The LIT-11626-20-60 owner's manual states it is OK to go ahead with riding when the message “Lo” is displayed. It also states "For maximum engine life, always warm the engine up before starting off. Never accelerate hard when the engine is cold!"
I think in general if the engine is cold, as in cold, it would be best to warm it up some.
mglowe is on it. Pretty much hop on a ride easily and smoothly until you are up to 165/175. If you hammer it cold you will accelerate ring and valve guide wear.
The fastest way to warm up any engine is to ride/drive it easily. Sitting takes a long time and does nothing but leave the cold idle circuit on longer = more pollution.
