Pseudo-Fed
Got her torn apart installing a FE. The stock turn signal wire colors are brown/black for left and green/black for right. Which is + and which is ground? Is black ground? Thanks.....
Have not done the FE kit, so take this with a grain of salt.... But, most of the time I have dealt with 12v, black is negative/ground/common...
Hope that helps. Might want a second opinion but i am 99% sure black is it. Most turn signals, unless you have polarized LEDs, will work if you have it flipped anyway.
By the way, which FE did you get?
