- Joined
- Feb 7, 2009
- Messages
- 12,531
- Reaction score
- 1,176
- Points
- 113
- Location
- Cape Coral, Florida, USA
The below links were taken from an FJR forum which I frequent.
The main difference between the FJR and the FZ6 TB's is that there is ONLY ONE throttle plate butterfly adjustment (between the 2 TB's for cylnders 1&2, adjustment screw, TB's 3&4), vs THREE on the FJR (4 separate TB's).
For some bikes that have more vibs than normal, especially in the higher rev range (where the a TBS has been done, Spark plug caps checked, etc), this is something to be checked should someone have previously dinked with the center adjustment , butterfly adjuster screw inadvertantly or on purpose.
NOTE, from personal experiance, (prior to purchasing a Morgan Carbtune) I had a Yamaha dealership do a sync on my old FJR. They ADJUSTED the TB 1/2 cylinder butterfly screw which is NOT SUPPOSED TO BE ADJUSTED. I had to set it back and do the sync correctly. (it was easier to access that butterfly screw than the air screw. Why they did this, ignorance, laziness, ?)
Some interesting reading and something to check for a bike vibrating more than usual, especially in the higher RPM range;
http://home.comcast.net/~FJR-NERDS/FJR_Tech_Stuff/The_RDCUA_TBS.htm
Error - FJRForum
And for filthy throttle plates and why;
Error - FJRForum
Just as a side re the links. "Fred W" is HIGHLY REGARDED on the forum and probably the most knowledgable person there with hands on experiance...
Error - FJRForum
Error - FJRForum
