Hey just wondering if anyone knows the proper size Torx key for the bolts that hold the Stator Assy to the inside of the Left side crankshaft cover. Any help is greatly appreciated!! Thanks guys!
I just did mine, they are tight (locttite) but they will come loose.
Things to know:
Loctite blue for the stator coil bolts.
Stator coil wire connection is just under the fuel tank. ( I did not even undo this when I changed my stator cover, did it right on the bike)
The screws to the stator coil is a T-30 Allen Star bit
The screws to the cover is a size 5 Allen bit
Also, the manual calls for 10Nm (7.2 ft-lb) for the stator coil bolts and 12Nm (8.7 ft-lb) for the cover bolts.
So I got the proper Torx key size. And the threadlocker, it's not Loctite but it's the equivalent I think. (Permatex, Medium Strength Threadlocker Blue)
Last question how did you know how tight to do each bolt considering they have different tightness recommendations. Just do it by feel or you got some tips? Thanks!
