The 20 commandments of motorcycle wisdom
MandyJo98
San Marcos, Texas
www.myspace.com
Thought it was pretty interesting and was wondering if anyone has any good riding experience advice ;)
1. Every ride is optional. Every parking job is mandatory.
2. If you push the bars left, the bike goes left. If you push the bars right, the bike goes right. That is, unless you continue pushing the bars all the way, then the bike will go down.
3. Riding isn't dangerous. Crashing is dangerous.
4. It's always better to be on the sidelines wishing you were on the track than on the track wishing you were on the sidelines.
5. The only time you have too much fuel is when you're on fire.
6. The rear wheel is just a big fan on back of the bike used to keep the rider cool and his/her butt relaxed. If going into a corner too fast, slamming on the rear brake causes the "fan" to abruptly stop. When this happens you can actually see the rider start sweating and his/her butt become tense.
7. When in doubt, slow down. No one has ever hit something too slow.
8. A 'good' ride is one from which you can walk away. A 'great' ride is one after which you can use the bike again.
9. Learn from the mistakes of others. You won't live long enough to make all of them yourself.
10. You know you've left the sidestand down when all left turn are Bat-turns. You know you've left the centerstand down when your in 1st gear at 4000 rpm going nowhere.
11. Never let a motorcycle take you somewhere your brain didn't get to three seconds earlier.
12. Always try to keep the number of times you put your sidestand down equal to the number of times you put the sidestand up.
13. There are two simple rules for riding smoothly and fast in snow and on ice. Unfortunately no one knows what they are.
14. You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
15. If all you can see in your mirrors is sparks and all you can hear is screaming from your passenger, things may not be as they should be.
16. In the ongoing battle between objects made of metal, rubber and fiberglass going 100+ miles per hour and the ground going zero miles per hour, the ground has yet to lose. Same holds for cars, large trucks, and animals taller than you. Draws don't count.
17. Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment.
18. Keep looking around. There's always something you've missed.
19. Remember, gravity and centrifical force are not just a good ideas. They're laws and are not subject to appeal.
20. The two most useless things to a rider are the braking distance behind you and nine-tenth of a second ago.
IndyFZ6
Den Haag
22. If the helmet is hanging on the helmet lock when you crash, you won't have time to put it on.:spank:
Shiny_side_up
Dublin, Ca
If the Internet has taught me anything, its that #13 is very nearly true.
One man knows the secret.
It's Chuck Norris - but unfortunately he's not telling.
that said, #8 was my favorite.
rsw81
Keep it Kosher
Boston, MA
Also, Chuck Norris' tears cure cancer, too bad he's never cried.
