zackeeboy
So I currently have my new Scorpion oval slip on exhaust installed along with the FAZR6 fender eliminator. With the FE installed, I was not able to install the little support that goes from the end of the fender up to the tail. I've also noticed that the black plastic shroud piece between the pipes is rubbing up against the license plate light holder, and rattles a bit when I hit bumps (pics below)
First question I have is if you think there is enough support for the fender without the bracket going up between the pipes? Will the two bolts under the tail be enough to hold it?
Secondly, any suggestions to stop the rattling? Should I try and attach the shroud to the license plate light to give it support? Any suggestions as to how to achieve this? Or do you think I should just cut off the section of plastic that is rubbing?
Thanks for the input!
