Steering Head Bearing Failure:
What Do You Think Causes Steering Head Bearing Failures?
  • Insufficient/Bad Factory Grease
    Votes: 7 16.7%
  • Bad Factory Seals = Water Damage
    Votes: 19 45.2%
  • Bad Original Bearings
    Votes: 7 16.7%
  • Factory Torque Settings When New
    Votes: 1 2.4%
  • Wheelies and/or Impacting The Front Forks
    Votes: 8 19.0%
  • Total voters
    42
  • Poll closed .
deeptekkie
TN
Having owned at least five other bikes before my Fazer I have never had to replace any steering head bearings. I had never heard of these bearing failures until I came to the forum. I am amazed how many folks have had problems. (I have had to replace two sets of swingarm bushings on dirt bikes)
There seems to be much dissention as to the cause of these failures.
Some folks say wheelies are the cause. Others that wheelie daily say "no problems". Some say water. Some say their bearings last forever while others have failures as soon as the warranty is gone, etc, etc, etc.
While I know that this poll will not generate any concrete evidence and it is based only on personal opinons, it IS (somewhat) based on owner's own personal experiences as well. I would like to hear everyone's opinion and just see what the general board's opinion is? This is for everyone whether or not you've had problems with your bearings. Thanks for your input.
stryken
Vertically Challenged
Imperial, Missouri
I have wondered the same thing and if it is something that only effects earlier years. Is it a problem that was fixed in the 2007 and up models or is it still an issue?
deeptekkie
TN
I too have wondered that myself. Lots of thoughts on this but I have noticed that on most of the photos that people have shown us, there is definitely rust. Since there is a bottom seal and a top cover, I wonder if water is getting in and not getting out? Too, their location exposes them to a lot of rising heat from the engine, (when parked while no air is flowing around them), which accelerates corrosion caused by moisture and a constant heating/cooling cycle of the factory-installed grease.
Wheelies can't be good for them, but how much different is that from hitting rough patches of pavement, (especially during heavy braking)? I just thought this a good chance to get input from a lot of Fazer riders/owners. That is one of the great things about this board: We have such a diverse cross section of riders and a huge storehouse of wisdom, information, and experience!
michael_p
Denmark
I think it might be the torque setting.
Too loose torque, causes water to enter.
When I changed my bearings, the nut was very loose :eek:
fzme
Senior Member
WV
I think you are right, but maybe someone with better info than me just thinking I remember could chime in...
Australia
I have an 06 FZ6 with 40000km's on it, and my bearing's are fine...i ride hard, but dont do wheelies.
I also live in a very dry climate.
If rust is an issue, then it is obviously water that is causing the problem, maybe those in colder climates, should protect their bearings, with a decent coating of grease on the outside, to protect from water getting in there...
Just my 2 cents again.
:thumbup:
FZ1inNH
********* w/ Twisted Fate
Dover, NH
I thought someone on here had discovered that the rubber plug on the bottom did not have a "weep hole" in it, or was it that it did have one and water was being driven up into the steering head?
Either way, I'm with Jamie. You can't over-grease them, right? :D
Australia
Yep, whatever the case, grease is a great way to keep water out of things....bit like when you put a frame plug on an FZ6, you will wanna make sure you grease the nut on the end of the swingarm bolt that resides behind your plug, cause condensation WILL build up behind the frame plug, and the end of the swingarm bolt & nut behind the frame plug, will corrode, or rust...
Grease...is the word! :D
Humperdinkel
Resident Rumologist
Ipswich , Australia (+10 GMT)
Ball bearings are the problem , replace with a new roller bearing like i did and you will NEVER look back :thumbup: or replace them again.... Improves the feel instantly.
Ridgeback
Wakin up the neighbours
Godalming UK
Hmm I'm beginning to think mine are a bit shonky.It's either that,or the forks are due a rebuild (17K miles)
deeptekkie
TN
When mine is up on the center stand there is no detectible resistance whatsoever when I move the bars. A bad setup would cause race damage, accelerated wear, and possile water leakage, among other things. (Now I'll worry!)
sxty8goats
Senior Member
Boston
Mine was pretty wonky last season. Bought the roller bearing to replace them but never got the time to do it. I store the bike 50 miles north of me a my buddies house. Ride on the weekends. That is job one this season followed by dropping it off to get tires. Hopefully that will all get done in the next couple weeks.
Wavex
Lazy Mod :D
Long Beach, CA
Owned 2 FZ6s and both needed the head bearing changed... Yamaha should have been using tapered bearings for such an application anyway, and I believe the main reason for the issues is the weak/bad plastic seal of the stock bearing...
S
Shamus McFeeley
Packing them with green grease should help too. Any water that does get in there will be repelled by the grease. I started using it with my dirt bikes and have continued to use it on my cars and street bikes. Great stuff, just don't get it where you don't want it, it makes a mess.
Grease PDF
deeptekkie
TN
Total agreement. While I've had no problems with mine, (and hopefully I'll be one of those that never will), I cannot speak from personal experience....
BUT: Looking at the schematics it appears that the bottom has an actual rubber seal while the top only has a "cover". Is this right guy/gals?
