Hello, Anyone know how to remove a steer tube form a lower triple tree? Any knowledge would help. Threading etc.
Thank you.
Thank you.
Do you know if it is the same on 08 R6 triple tree?
Kind of figuring this out. I believe that I am going to have a custom steer tube made to press fit into the r6 triple tree, grind down off the original steer lock and make some of my own.
Is there a retaining ring on the lower of the R6 steer tube? If so how can I remove both so I can have them pressed out?
I purchased a gold 2008 R6 inverted fork recently and will do what it takes to have it modified to fit. I believe the steer tube is the biggest modification to be made. The steering lock is a small issue comparatively.
Thank you all for your advice
