jody.adams
I installed a Stebel on my 2008 FZ6 tonight and took plenty of pics. I was unhappy with most of the installs I've seen online thus far as they are either too exposed or done with velcro and zip ties. I'm not trying to knock others efforts. I just wanted some kind of mechanical fastener due to the weight of the horn and vibration and I wanted the horn hidden.
I used a single stainless 1/4-20 x 1" screw with a nylon spacer and a square nut. I had to drill one hole in the plastics which leaves an exposed head, but it looks like it belongs there. For those of you that want the easiest most discreet looking Stebel install, I'd say this is about the best spot for the unit.
I pulled power after the main relay so that the horn would not function when the key was off. I also installed a 20 amp fuse block prior to the horn. The relay is mounted using one of the existing panel screws. If it pukes, I can swap it out in 5 minutes.
I installed foam mounting tape in between the horn and the panel wherever there was contact to minimize vibration. It worked out real well. I can lay on the horn and there is no buzzing in the plastics.
HOOONNNNK!!!
HOOONNNNK!!!
