sideslider
looks like mine
Thats crazy. I haven't even got mine yet and im 6 hours from the shipping point!![]()
I set mine up with GPS, and -09.1 was dead on. It might be a starting point for those withoutaccess toGPS.
Naw I'll wait. I got ben to ship from his house to canada. Could be hung up at the border maybe? I hope it's here soon though!
well it's used for calibration.. it reads p, - a b n o e and 0-9
basically you have to enter in a percentage in 00.0 fromat, there is a setting to tell it if you are using 000.0 or 00.0 format and then there is test mode and a and b memory channels...
doesnt really show much unless you mess with it... it does make the speedometer display things though.
I haven't been able to get positive confirmation that it will enable our dumbassed Canadian KPH speedo's to read in MPH yet.....I'm hoping you'll be able to confirm that it does when you get yours installed.:thumbup:
I have mine set to -9.1 with the standard 16t sprocket. It matches my Tom Tom exactly.So you got -9.1 with the 15tooth? Using their online calculator and using the 7% stock error it would be -12.9%.
Does anyone else have input thats gps verified on what I should be setting it to with the 15tooth.
This is correct the unit can be calibrated to view KPH or MPH.There is a setting you add \"C\" that is supposed to convert it. I've left mine as is and it reads properly in km/h. i'll check it when i switch programs for my 15 tooth sprocket. My guess is it will convert to mph. The top speed function is neat too.
