What size is that rear? Looks like a 190!
That's what came into my mind too. Possibly the incorrect tire size on the rear. I suggest to the OP to get the Michelin Pilot Road 3 or 4's if the rides involve a lot of highway.
I ordered some Dunlop Q2 Sportmax for front ($96 shipped) and rear($115 shipped).
Any tire that fits from a good tire company will be an improvement. As to brand....... Some folks like Chocolate, some strawberry. Motorcycles are not cars. That seems simple enough but riders that should know better forget. If you want a car to handle better you lower it and put on wider tires. Do that to a motorcycle and you ruin the handling.
All things being equal, a thinner tire allows a motorcycle to transition quicker.
Transition is going from leaned over right to leaned over left. Or back straight up, depending. Since changing directions on a motorcycle is done by a combination of turning the forks and leaning the quicker you get into the lean, the quicker you turn. Yet traction decreases with lean angle. The contact patch of your tire (tyre in Great Britain) gets smaller as the lean angle increases. Your bike was designed with a certain size tyre (tire in the USA) in mind. The suspension components, Frame, controls, everything is supposed to work together as a unit.
Supposed to. The FZ-6 does better then most at that.
Buy good tires, or tyres if you must. Check the pressure EVERY DAY. While cold. Maintain that pressure at what the tire says. The sticker on the bike was for the tires that came with the bike.
Tires are regular replacement items. Start a tire fund. Throw a 10 in the back of your nightstand drawer every week. When you cannot see anything but slick rubber it's time for tires. Dig that stack of 10's out and see what is on sale. Do NOT ride in the rain on slick tyres!
^^ Well said!! :thumbup:
Although I would set pressure according to Vehicle Load Placard / "Vehicle Recommended Pressure" vs tire's MAX pressure for load. Some tires will fit larger heavier vehicles and setting the MAX TIRE pressure results in over inflation and the potential for LOST Traction! Be careful!
