Redline Water Wetter
Ryan T
P.P.P.P.P.P
Woodbridge VA
Hello all my Forum Brothers and Sisters,
Does anyone know or have an opinion on using Redline Water Wetter in the bike. I'm about to do a radiator flush and fill and trying to see what's going to be my very best option.
Thanks in advance for all the advice, comments, and crazy answers.
Cali rider
Well-Known Member
Buena Park, California
Lots of information in this document: http://www.redlineoil.com/content/files/tech/WaterWetter Tech Info.pdf
Pros:
- Will allow the cooling system to run more efficiently. It will take away a heat load better than any coolant mixture, but it won't necessarily make the fluid temperature drop. IOW, if you ride under normal conditions you won't notice a difference, but if heat load increases a lot it WILL keep your bike running cooler than antifreeze will.
- If it spills due to a leak it has about the same effect as water in regard to traction loss. Take it from me, antifreeze is VERY slick if you ride over it while leaned over...
- It has the same corrosion protection as other coolants.
Cons (Only one that I can think of):
- As mentioned, it offers ZERO freeze protection and ZERO boilover protection. The high temp is not a problem, but the low temp is something to consider. You can't ignore this fact.
I use it in my bikes as I never leave either of them in an environment where the engine will cool below freezing. I mix it with distilled water, one bottle will last several years when properly diluted.
Discofrank
Lesmurdie
have it in the car for over 5yrs
still cant get teh ****ign thing hot ona 40 deg day going up a hill, foot to the floor aircon on..
1 bottle is for a car ie 12 ltres of water
u need like 1/4 of this ;)
RJ2112
Dahlgren, VA/USA
www.etsy.com
Pros:
Thanks for the link.....
According to their own document, you can use 'wetter' with the std 50/50 water/glycol antifreeze, and get the best heat transfer performance... better than typical water/glycol mixes by measureable amounts.
Seems to me, if your bike is not going on the track..... this would the be best of all combinations. I wonder what the correct mix would be in that scenario? 1/3:1/3:1/3?
