ant_mb
Super *********
I know it can be done, but how do I make my rear signals running lights. I know it is illegal but don't really care. Anyone out there done it, or know how?
It prevents confusion and to which direction a vehicle is moving.
...I know it is illegal but don't really care.
Very well said. More confusion with the confused is what we do not need.
I wish we could change your mindset about not caring of the legalities of such a mod. While it may not seem so, it's dangerous both to you and others you share the road with.
A red LED in an amber housing will not be very visable. LEDs emit light only in the wavelength specific to their color. The amber lense on the turn signal takes the multitude of colors from the incandescant bulb and only lets the amber wavelengths through. A red LED has minimal, if any, wavelengths in the amber range so you will not get as much light out of it. Id go with a seperate red LED. That's what I plan on doing eventually. Check out SUPER BRIGHT LEDS home They have a multitude of waterproof 12v LED optionscould do some red led's in the turnsignal housing.. that would work, as far as running lights in your rear turnsignals, easiest way is to get a set of front turn signals and wire them in , how about a red bulb. that would be legal in the turn signals, hence corvette, etc.....
If you gotta do it, I see two options. Either run the 3 wires from the front lights to the back, one set for each site, or use the existing signal wires at the back and tap into the tail light for the running lights.
So if the running lights are red then it's not illegal? I see Gold Wings decked out with a ton of red lights in the rear. I guess that would explain it.![]()
Why don't you get some Hyper Lites, they act as running lights as well as brakelights. They are super super bright. I'm sure the guys who were behind me on our group rides through the twisties can verify that they are bright. So bright that I can't believe they are legal. At night, they are so blindingly bright, you can't read my license plate. Pictures here do no justice.
Perhaps this site has something your interested in? You would have to consider some extra hardware but it looks promising.
INCREASING REAR VISIBILITY
