RJ2112
- Joined
- Mar 25, 2009
- Messages
- 2,108
- Reaction score
- 23
- Points
- 0
- Location
- Dahlgren, VA/USA
I don't think the trail has been affected, assuming the fork tubes are the same length. If you take a plumb bob and mark where the center of the axle is, that's the end point of the trail measurement.
When you move the axle 'back' (because the forks are moved 'back') the end point of the trail calculation moves back an equal amount. If the fork angle doesn't change, the rake doesn't change.... the point the measurement starts from also moves back an equal amount. In algebraic terms you've subtracted equally, from all parts of the equation.
The only number that would change, would be wheel base, which is measured from axle centerline to axle centerline. Bringing the fork tubes 'aft' will cause the axles to be that much closer together.
