- Joined
- Feb 7, 2009
- Messages
- 12,531
- Reaction score
- 1,176
- Points
- 113
- Location
- Cape Coral, Florida, USA
I don't know if that's from factory Scott, I am the third owner of my bike. It's possible that it has been messed about with before? I haven't had any running issues other than once you synch the throttle bodies you do notice when they need to be done again.
I think that with the home made manometers a heavier oil is also key because the vacuum created is pretty strong, a heavier oil doesn't bounce around as much. It's also wise to get the vacuum valves to protect the engine from sucking in the contents of the line (which nearly happened to me on mk 1).
incidentally because of weathering I am not able to identify the pink line on #1 & #4. can I identify which line goes to each cylinder based on their length.
I answered my own question Re: Build your own Manometer for Throttle Body Sync!
I did mine today, Thanks very much for the "How to".
It was much better than the Haynes manual.
Just a couple of things to add.
1. I am using 10w 40 oil. I tried a lighter oil but found that the heavier oil was much more stable in the tubes.
2. Don't disconnect the manometer with the engine running. I nearly ended up with throttle bodies full of oil.
3. My vacuum tubes did not have the purple markings on ( probably worn of with age). #1 and #4 tubes are longer than # 2 & # 3 on my bike.
Nelly
Great pointers!
If you wanted, just a spot of white paint (or "white out"-if they still make it) on the outside hoses would keep you from having to look for the longer INSIDE hoses (#'s 2 & 3).
Even a plastic zip tie, on the very loose side, would help/work...
