Question for March 27, 2008
J
jsteinb95
Suppose you're in a hallway lined with 100 closed lockers.
You begin by opening every locker. Then you close every second locker. Then you go to every third locker and open it (if it's closed) or close it (if it's open). Let's call this action toggling a locker. Continue toggling every nth locker on pass number n. After 100 passes, where you toggle only locker #100, how many lockers are open?
3,000 credits for the correct answer!!!!!
PM me your answer.
Nelly
International Liaison
Co Offaly, ROI
PM me your answer.
Screw that J, how pissed would you be cause you didn't find what you were after lol.
No I don't know the answer.
NELLY
J
jsteinb95
Answer for March 27
Answer: 10 lockers are left open:
Lockers #1, 4, 9, 16, 25, 36, 49, 64, 81, and 100.
Each of these numbers are perfect squares. This problem is based on the factors of the locker number.
Each locker is toggled by each factor; for example, locker #40 is toggled on pass number 1, 2, 4, 5, 8, 10, 20, and 40. That's eight toggles: open-closed-open-closed-open-closed-open-closed.
The only way a locker could be left open is if it is toggled an odd number of times. The only numbers with an odd number of factors are the perfect
squares. Thus, the perfect squares are left open.
For example, locker #25 is toggled on pass number 1, 5, and 25 (three toggles): open-closed-open.
Zebratounge, reiobard and grommit got the correct answer!!!!
