- Joined
- Feb 7, 2009
- Messages
- 12,920
- Reaction score
- 1,725
- Points
- 113
- Location
- Cape Coral, Florida, USA
Just an FYI, I had my tank up yesterday doing a TB sync.
When setting the tank back down (I have risers/set-backs) so I have to pull the rear bolt, lift the tank, then re-install the rear bolt.
Once done with my sync, and the tank set back down, I found the left side hose, from the tank, trying to kink at the rear of the tank, left side(before it exits near the shock). With a good flashlight, a long screwdriver, I was able to straighten the line out. The right side just about fell into place.. Both lines (stock lines) both exit the RS, by the O2 sensor. There is a plastic ring that I ran both hoses thru.
IF, one of those hoses is shorter than the other, (and it has't been cut) its going to be kinked... Just something to be aware of / check if the gas cap is clear..
