I was looking for the vent line to my gas tank and came across this line that I am not sure what it is or where it leads. It looks like it's coming from my tank but it is blocked. Does anyone know what this is?
I wouldn't worry about it. I think there are 3 hoses from the tank that hang down, 2 of them are over-flow hoses, and that would be the third. Not sure what it's for, could be something the factory uses for pressure testing???
Edit: Removed bogus info. :spank: Have the same one, plugged just as you have, in addition to the two vent hoses hanging down to just above the center stand.
They should be coming out under the frame behind where the center stand bolts are. You'll see three hoses with angle cut ends. Two are gas tank vent hoses and the last is for the coolant overflow tank.
