Caesar
I was looking for the vent line to my gas tank and came across this line that I am not sure what it is or where it leads. It looks like it's coming from my tank but it is blocked. Does anyone know what this is?
Ok so where can I find the vent hose for the gas tank without lifting the tankThat's one of the vacuum ports so you can synch the throttle bodies.
They should be coming out under the frame behind where the center stand bolts are. You'll see three hoses with angle cut ends. Two are gas tank vent hoses and the last is for the coolant overflow tank.
